    Evok & NodeRed backup/restore
    2 Posts 2 Posters 2.0k Views
    • H
      honza.muller
      I am going to upgrade NodeRed image to the newest version. What do I need to backup before upgrade? I assume i should backup NodeRed configuration, /etc/evok.conf file, but what next? Also, is there any changelog where can i check, what have changed? Thank you!
        robinr1
        I performed an update today to the newest nodered OS image.
        I took a OS backup using the service mode, to be safe
        I took a file copy backup of /home/unipi and /etc
        I flashed the new image
        boot into the new image
        set timezone
        $ sudo timedatectl set-timezone Europe/Brussels
        installed latest updates
        $ sudo apt-get update
        $ sudo apt-get upgrade
        updated unipi firmware:
        $ sudo /opt/unipi/tools/fwspi -u 1 -v -P -U
        Stopped node-red
        $ sudo systemctl stop node-red
        moved /home/unipi/.node-red to /home/unipi/.node-red.old
        copied /home/unipi/.node-red and /home/unipi/node_modules from the file-backup to the current system
        rebooted unipi
        Node-red came up with correct config. Inside Node-red I had to update the @unipitechnology/node-red-contrib-unipi-evok node-palette to v0.0.8 and then had to replace all unipi-evok inputs and outputs by their respective unipi-evok-v3 counterparts.
        After that everything seems to be up and running again. (apart from my 1Wire temp sensor which seems no longer be detected by Evok.. but that is out of scope here, I assume)
        Possibly you may have to configure more and or re-apply changes you did on previous OS image. (I had to also install and configure mosquitto mqtt for example.)
