    Reading the ModBus bus with the Patron
    Other Peripherals
    • Vesa Kauppinen
      Vesa Kauppinen last edited by
      I have tested to read the Kamstrup 803 meter on the Patron M527 via Modbus.
      However, I don't get any results from mbpoll.
      root@M527-sn60:~# mbpoll /dev/extcomm/0/1 -m rtu -P none -d 8 -s 1 -b 19200 -a 44
      mbpoll 1.4-12 - FieldTalk(tm) Modbus(R) Master Simulator
      Copyright © 2015-2019 Pascal JEAN, https://github.com/epsilonrt/mbpoll
      This program comes with ABSOLUTELY NO WARRANTY.
      This is free software, and you are welcome to redistribute it
      under certain conditions; type 'mbpoll -w' for details.
      Protocol configuration: Modbus RTU
      Slave configuration...: address = [44]
                              start reference = 1, count = 1
      Communication.........: /dev/extcomm/0/1,      19200-8N1
                              t/o 1.00 s, poll rate 1000 ms
      Data type.............: 16-bit register, output (holding) register table
      -- Polling slave 44... Ctrl-C to stop)
      Read output (holding) register failed: Connection timed out
      Same result on mbpoll /dev/extcomm/0/0 -m rtu -P none -d 8 -s 1 -b 19200 -a 44
      Br,
      Vesa
        AVsetula administrators last edited by AVsetula
        Hello Vesa,
        Only some Patron ports are available using the deprecated /dev/extcomm/Y/X notation.
        I recommend using the ports from the table in this article: Patron serial port mapping
        To verify communication with all our Modbus devices, I recommend asking the holding register 1003, which is available for all Modbus devices Unipi and whith contains a unique identifier, according to which the device can also be recognized.
        Antonin
        Vesa Kauppinen 1 Reply Last reply Reply Quote 0
        • Vesa Kauppinen
          Vesa Kauppinen @AVsetula last edited by
          How can i ask the holding register 1003 with mbpoll?
          @AVsetula said in Reading the ModBus bus with the Patron:
          Thank you!
          /Vesa
          A 1 Reply Last reply Reply Quote 0
            AVsetula administrators @Vesa Kauppinen last edited by
            Hi @Vesa-Kauppinen,
            From Unipi Patron I/O boards by:
            • Section 1: mbpoll -m tcp 127.0.0.1 -a 0 -0 -1 -r 1003 -p 502
            • Section 2: mbpoll -m tcp 127.0.0.1 -a 0 -0 -1 -r 1103 -p 502
            • Section 3: mbpoll -m tcp 127.0.0.1 -a 0 -0 -1 -r 1203 -p 502
            And from Unipi Extension using ttyNS0 port:
            • mbpoll -m rtu /dev/ttyNS0 -b 19200 -P none -0 -1 -r 1003 -a 15
            Antonin
