    EVOK a xS11 chyba
    • K
      kratas last edited by kratas
      Ahoj,
      mám unipi Patron M207 a rozšiřující modul xS11, v evok.conf jsem nastavil rozšiřující modul, v evoku ho vidím, vstupy a výstupy, ovládání relé funguje.
      Potřebuju ale na inputech u rozšiřujícího modulu nastavit direct switch, stejně jako u M207, bohužel to ale vždy skončí chybovou hláškou.
      evok.conf
      [MAIN]                                          ; !!! ALL MAIN SECTION OPTIONS ARE MANDATORY !!!
      config_version = 2.5                            ; Configuration file version, DO NOT CHANGE!
      use_schema_verification = False                 ; Enabling this will deny any requests that do not match the JSON Schema; NOTE THAT THIS RESULTS IN A SIGNIFICANT INCREASE IN LATENCY AND SHOULD NOT BE USED EXCEPT FOR TESTING
      log_level = ERROR                               ; Minimum severity of messages to be logged; one of INFO, DEBUG, WARNING, ERROR, CRITICAL
      log_file = /var/log/evok.log                    ; Log file to use; will be cleared on boot
      port = 8080                                     ; !!! Internal API port - only change if you are certain you know what you are doing; FOR OUR WEB INTERFACE THE PORT SHOULD BE CHANGED IN "/etc/evok-nginx.conf" INSTEAD !!!
      webhook_enabled = False                         ; Enables webhook notification - see e.g. https://sendgrid.com/blog/whats-webhook/
      webhook_address = http://127.0.0.1:80           ; Put your server endpoint address here (e.g. http://123.123.123.123:/wh )
      webhook_device_mask = ["input","wd"]            ; List of device types to notify on (written as a JSON list) - adding AI will generate a large amount of messages!
      webhook_complex_events = False                  ; EVOK will send POST requests with the same data as WebSocket, rather than an empty GET request
      soap_server_enabled = False                     ; Enables the simple SOAP server; use only if you need the functionality
      soap_server_port = 8081                         ; !!! IF SOAP SERVER IS ENABLED, THIS PORT NEEDS TO BE UNIQUE (i.e. different from the port setting above) !!!
      force_immediate_state_changes = False           ; Outputs will return the value they are set to, rather than the value that the device is currently aware of
      websocket_all_filtered = False                  ; 'All' WebSocket requests will be subject to the filtering set by 'filter'
      [NEURON_1]
      global_id = 1                                   ; Mandatory, REQUIRED TO BE UNIQUE
      allow_register_access = False                   ; Optional, False default
      scan_frequency = 10                             ; Optional, 10 default, scanning frequency in [Hz]
      scan_enabled = True                             ; Optional, True default
      ; Below you can find examples for connecting devices over UART; first example is a Neuron extension while the second is a custom third-party device
      ; Devices sharing a port use the port settings of the first device on that port (baud rate, parity, stop bits)
      ; !!! Note that device_name has to match a filename in the /etc/hw_definitions directory !!! See /etc/hw_definitions/CUSTOM_MODBUS_DEVICE.yaml for an example
      [EXTENSION_1]
      global_id = 2                                   ; Mandatory, REQUIRED TO BE UNIQUE
      device_name = xS11                              ; Mandatory, must match name of .yaml modbus map file in /etc/hw_definitions
      modbus_uart_port = /dev/extcomm/0/0             ; Mandatory
      neuron_uart_circuit = 1_01                      ; Optional, allows associating extensions with specific Neuron UART-over-Modbus ports (not possible for non-Modbus UART ports, e.g. /dev/ttyUSB0 or /dev/ttyS0)
      allow_register_access = False                   ; Optional, False default, is mandatory with third-party devices
      address = 1                                     ; Optional, 1 default
      ;baud_rate = 115200                             ; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORTS! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
      ;parity = N                                     ; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORTS! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
      ;stop_bits = 1                                  ; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORTS! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
      ;[EXTENSION_2]
      ;global_id = 3                                  ; Mandatory, REQUIRED TO BE UNIQUE
      ;device_name = CUSTOM MODBUS DEVICE             ; Mandatory, must match name of .yaml modbus map file in /etc/hw_definitions
      ;modbus_uart_port = /dev/extcomm/0/0            ; Mandatory
      ;neuron_uart_circuit = 1_01                     ; Optional, allows associating extensions with specific Neuron UART-over-Modbus ports (not possible for non-Modbus UART ports, e.g. /dev/ttyUSB0 or /dev/ttyS0)
      ;allow_register_access = True                   ; Mandatory with third-party devices
      ;address = 1                                    ; Optional, 15 default
      ;scan_frequency = 2                             ; Optional, 1 default, scanning frequency in [Hz]
      ;scan_enabled = True                            ; Optional, True default
      [OWBUS_1]
      owbus = /dev/i2c-2                              ; Mandatory, scanned bus (--i2c=/dev/i2c-1:ALL or localhost:2122 or 'u' for USB dongle)
      interval = 3                                    ; Mandatory, [s] length of sensor reading
      scan_interval = 300                             ; Mandatory, [s] How often the scanning is done
      ; See below for 1Wire extension module configuration
      ; Example for the 1W-4R/4DI extension module, 1W-8R is almost the same, only with inputs instead of relays
      ; - Map a new 1Wire sensor with the appropriate address, type and interval
      ; - The syntax can be either SENSOR or 1WDEVICE
      ; - Setting the correct reading interval is crucial to achieve ideal performance; the default interval is 15s
      ;[1WDEVICE_2]
      ;bus = 1
      ;address = 29F39A17000000BC
      ;type = DS2408
      ;interval = 1
      ;[1WRELAY_10]
      ;sensor = 2
      ;pin = 0
      ;[1WRELAY_11]
      ;sensor = 2
      ;pin = 1
      ;[1WRELAY_12]
      ;sensor = 2
      ;pin = 2
      ;[1WRELAY_13]
      ;sensor = 2
      ;pin = 3
      ;[1WINPUT_20]
      ;sensor = 2
      ;pin = 4
      ;[1WINPUT_21]
      ;sensor = 2
      ;pin = 5
      ;[1WINPUT_22]
      ;sensor = 2
      ;pin = 6
      ;[1WINPUT_23]
      ;sensor = 2
      ;pin = 7
      verze OS je poslední node-RED
      patron-node-red_image.20220103.0.zip
      Mám někde něco špatně já, nebo co by mohl být problém, že mi nejde nastavení uložit ? Název vstupu/výstupu se uloží i přes chybovou hlášku, nastavení bohužel ne a to je pro mě klíčové.
      Díky
      Adam
      • K
        Opravdu žádné řešení? :-(
        • K
          kratas @kratas last edited by
          evok je poslední verze 2.4.12, zkoušel jsem i starší, tam to žádnou chybovou hlášku nehodí, ale změna se neprovede.
          Ikdyž to vypadá, že ano, po restartu, je v nastavení opět simple a direct switch se neuložil.
            cyberbob last edited by
            Toto by mne také zajímalo. xS11 ovládat můžu, ale DirectSwitch rozjet nedokážu. Zkoušel jsem vyčíst status registru pomoci mbpoll, ale tam se mi nepodařilo získat smysluplná data.
