Navigation
    filter websocket input in order to get all devices except temp
    1
      juntiedt last edited by
      I want to receive all devices via websocket except one wire sensors. How has the filter command to look like?
      All devices but temp or temp and no other device.
      I am using node-red with the websocket set command which works ok, but the filter command seems not to work.
      Any help appreciated.
        I have solved the problem. Sorry for the quick post.
        Attached please find the command flow for filter
        [{"id":"46e364e3.e7c2ec","type":"function","z":"cad50249.94c0e","name":"","func":"msg.payload = {\"cmd\":\"filter\", \"devices\":[\"ai\",\"input\",\"ao\",\"relay\"]}; \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":280,"y":860,"wires":[["a3e4b046.69f93","c16f715d.8fbe1"]]},{"id":"c16f715d.8fbe1","type":"websocket out","z":"cad50249.94c0e","name":"ws://localhost:8080/ws","server":"","client":"84e45387.411c2","x":540,"y":860,"wires":[]},{"id":"418d6f8c.c0e61","type":"inject","z":"cad50249.94c0e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"5","topic":"","payload":"","payloadType":"date","x":110,"y":860,"wires":[["46e364e3.e7c2ec"]]},{"id":"84e45387.411c2","type":"websocket-client","z":"","path":"ws://localhost:8080/ws","tls":"","wholemsg":"false"}]
          one important thing at the end:
          as soon as you apply a filter the received msg.payload from websocket comes in an array.
          this means:
          before the applied filter you could your device with msg.payload.dev
          with applied filter you must read the device as msg.payload[0].dev !!!
