Build-In 1Wire does not work!
Hi all,
I have a Neuron M103 which has USB and a 1-wire interface.
When I connect my sensors to the build-in port I do not find them. Connecting through a USB adapter works flawlessly!
Any idea?
I changed /etc/owfs.conf according to the device I am using. Disabled the FAKE device and tried to enable the i2c:#server: FAKE = DS18S20,DS2405 # Setting for Neuron M103 server: device = /dev/i2c-1 # # USB device: DS9490 #server: usb = allNow when I do i2cdetect -l I get the correct one I used in above owfs.conf:
i2c-1 i2c bcm2835 I2C adapter I2C adapterSeems to be the bus is recognized properly:
root@zentrale:/heizung/src# i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- 18 -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- UU 70: -- -- -- -- -- -- -- --Changing the device to i2c-1 in owfs.conf, restarting owfs and switching cable to Neuron port I do not get any device:
root@zentrale:/heizung/src# owdir /bus.0 /uncached /settings /system /statistics /structure /simultaneous /alarmSwitching everything back to USB I get proper information:
root@zentrale:/heizung/src# owdir /10.A224A3010800 /10.520F86010800 /10.1911A3010800 /10.2720A3010800 /28.301FF8030000 /28.5AFFBD030000 /28.8BF2BD030000 /28.0FFCBD030000 /28.FF0061711404 /28.FFC4C5701404 /28.FF92E8701404 /28.FF8A5F711404 /28.FFFAE9701404 /28.FF66E8701404 /28.FF56E9701404 /28.FF7E11711404 /28.FF6D90711404 /28.FF7D12711404 /26.29AB40010000 /81.A08830000000 /bus.0 /uncached /settings /system /statistics /structure /simultaneous /alarmAny idea how to use the build-in i2c-1-wire-bus?
Greetings
/KNEBB
