    Neuron M103 + xS10 no RS485 connection
    1
    • L
      Lubo last edited by
      I would like use M103 + xS10 + 1wire HUB (current with 1 temperature sensor) for home automation with Node Red. So I have followed UniPian installation instructions in: https://kb.unipi.technology/en:sw:03-3rd-party:nodered:installation-neuron .
      • Image installation: UniPian-Neuron-OS-2019-01-07-v1.9.img
      • then Evok installation and update to version 2.1.6 :
      sudo su
      apt-get install evok
      apt-get update
      reboot
      After EVOK installation and update, there is no Modbus communication with xS10 extension. No additional Extension mapped in Unipi Control Panel except S102.
      Current status of both units:
      • Neuron S102:
        • Rx/Tx leds are OFF
        • UART port configuration Parity: None, Speed:19200, Stopbits: One
        • RS485 END: ON
        • 50cm wiring A-A, B-B
      • xS10:
        • power led (red) is ON
        • status led (green) is flashing
        • dip switches: 1.ON, 2.OFF, 3.ON, 4.OFF, 5.OFF, 6. OFF, 7. ON
      pi@M103_2-sn465:~ $ cat /etc/evok.conf
      [MAIN]        ; !!! ALL MAIN SECTION OPTIONS ARE MANDATORY !!!
      config_version = 2.5                                    ; Configuration file version, DO NOT CHANGE!
      use_schema_verification = False                 ; Enabling this will deny any requests that do not match the JSON Schema; NOTE THAT THIS RESULTS IN A SIGNIFICANT INCREASE IN LATENCY AND SHOULD NOT BE USED EXCEPT FOR TESTING
      log_level = ERROR                                       ; Minimum severity of messages to be logged; one of INFO, DEBUG, WARNING, ERROR, CRITICAL
      log_file = /var/log/evok.log                    ; Log file to use; will be cleared on boot
      port = 8080                                                             ; !!! Internal API port - only change if you are certain you know what you are doing; FOR OUR WEB INTERFACE THE PORT SHOULD BE CHANGED IN "/etc/evok-nginx.conf" INSTEAD !!!
      webhook_enabled = False                                 ; Enables webhook notification - see e.g. https://sendgrid.com/blog/whats-webhook/
      webhook_address = http://127.0.0.1:80   ; Put your server endpoint address here (e.g. http://123.123.123.123:/wh )
      webhook_device_mask = ["input","wd"]    ; List of device types to notify on (written as a JSON list) - adding AI will generate a large amount of messages!
      webhook_complex_events = False                  ; EVOK will send POST requests with the same data as WebSocket, rather than an empty GET request
      wifi_control_enabled = False                    ; !!! REQUIRES THE UNIPIAP WIFI CONTROLLER TO BE INSTALLED !!! Will allow evok to control the internal Neuron wifi
      soap_server_enabled = False                             ; Enables the simple SOAP server; use only if you need the functionality
      soap_server_port = 8081                                 ; !!! IF SOAP SERVER IS ENABLED, THIS PORT NEEDS TO BE UNIQUE (i.e. different from the port setting above) !!!
      [NEURON_1]
      global_id = 1                                                   ; Mandatory, REQUIRED TO BE UNIQUE
      allow_register_access = False                   ; Optional, False default
      scan_frequency = 10                                             ; Optional, 10 default, scanning frequency in [Hz]
      scan_enabled = True                                     ; Optional, True default
      ; Below you can find examples for connecting devices over UART; first example is a Neuron extension while the second is a custom third-party device
      ; Devices sharing a port use the port settings of the first device on that port (baud rate, parity, stop bits)
      ; !!! Note that device_name has to match a filename in the /etc/hw_definitions directory !!! See /etc/hw_definitions/CUSTOM MODBUS DEVICE.yaml for an example
      ;[EXTENSION_1]
      ;global_id = 2                                                  ; Mandatory, REQUIRED TO BE UNIQUE
      ;device_name = xS10                                             ; Mandatory
      ;modbus_uart_port = /dev/extcomm/0/0    ; Mandatory
      ;neuron_uart_circuit = 1_01                             ; Optional, allows associating extensions with specific Neuron UART-over-Modbus ports (not possible for non-Modbus UART ports, e.g. /dev/ttyUSB0 or /dev/ttyS0)
      ;allow_register_access = True                   ; Optional, False default, is mandatory with third-party devices
      ;address = 1                                                    ; Optional, 1 default
      ;scan_frequency = 10                                    ; Optional, 10 default, scanning frequency in [Hz]
      ;scan_enabled = True                                    ; Optional, True default
      ;baud_rate = 19200                                              ; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORTS! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
      ;parity = N                                                             ; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORTS! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
      ;stop_bits = 1                                                  ; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORTS! USE API TO CONFIGURE UART MANUALLY IF USING STANDARD RASPBIAN
      ;[EXTENSION_2]
      ;global_id = 3                                                  ; Mandatory, REQUIRED TO BE UNIQUE
      ;device_name = CUSTOM MODBUS DEVICE             ; Mandatory
      ;allow_register_access = True                   ; Mandatory with third-party devices
      ;address = 1                                                    ; Optional, 15 default
      ;scan_frequency = 2                                     ; Optional, 1 default, scanning frequency in [Hz]
      [OWBUS_1]
      owbus = /dev/i2c-1 --i2c=/dev/i2c-1:ALL ; Mandatory, scanned bus (--i2c=/dev/i2c-1:ALL or localhost:2122 or 'u' for USB dongle)
      interval = 3                                            ; Mandatory, [s] length of sensor reading
      scan_interval = 300                                     ; Mandatory, [s] How often the scanning is done
      ; See below for 1Wire extension module configuration
      ; Example for the 1W-4R/4DI extension module, 1W-8R is almost the same, only with inputs instead of relays
      ; - Map a new 1Wire sensor with the appropriate address, type and interval
      ; - The syntax can be either SENSOR or 1WDEVICE
      ; - Setting the correct reading interval is crucial to achieve ideal performance; the default interval is 15s
      ;[1WDEVICE_2]
      ;bus = 1
      ;address = 29F39A17000000BC
      ;type = DS2408
      ;interval = 1
      ;[1WRELAY_10]
      ;sensor = 2
      ;pin = 0
      ;[1WRELAY_11]
      ;sensor = 2
      ;pin = 1
      ;[1WRELAY_12]
      ;sensor = 2
      ;pin = 2
      ;[1WRELAY_13]
      ;sensor = 2
      ;pin = 3
      ;[1WINPUT_20]
      ;sensor = 2
      ;pin = 4
      ;[1WINPUT_21]
      ;sensor = 2
      ;pin = 5
      ;[1WINPUT_22]
      ;sensor = 2
      ;pin = 6
      ;[1WINPUT_23]
      ;sensor = 2
      ;pin = 7
      pi@M103_2-sn465:~ $ sudo systemctl status evok
      ● evok.service - EVOK ModBus/WebSocket/RPC Server
         Loaded: loaded (/lib/systemd/system/evok.service; enabled; vendor preset: enabled)
         Active: active (running) since Fri 2019-11-15 17:55:11 GMT; 39min ago
        Process: 794 ExecStartPre=/bin/ln -sf /etc/nginx/sites-enabled/evok /etc/evok-nginx.conf (code=exited, status=0/SUCCESS)
        Process: 791 ExecStartPre=/bin/rm -f /etc/nginx/sites-enabled/mervis (code=exited, status=0/SUCCESS)
        Process: 788 ExecStartPre=/bin/mv -f /etc/nginx/sites-enabled/mervis /etc/nginx/sites-available/ (code=exited, status=1/FAILURE)
        Process: 720 ExecStartPre=/bin/cp -f /etc/nginx/sites-available/evok /etc/nginx/sites-enabled/ (code=exited, status=0/SUCCESS)
       Main PID: 797 (python)
         CGroup: /system.slice/evok.service
                 ├─797 /opt/evok/bin/python /opt/evok/lib/python2.7/site-packages/evok/evok.py
                 └─866 /opt/evok/bin/python /opt/evok/lib/python2.7/site-packages/evok/evok.py
      Nov 15 18:05:16 M103_2-sn465 OWFS[866]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
      Nov 15 18:10:16 M103_2-sn465 OWFS[866]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
      Nov 15 18:12:16 M103_2-sn465 OWFS[866]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
      Nov 15 18:15:16 M103_2-sn465 OWFS[866]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
      Nov 15 18:17:16 M103_2-sn465 OWFS[866]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
      Nov 15 18:20:17 M103_2-sn465 OWFS[866]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
      Nov 15 18:25:17 M103_2-sn465 OWFS[866]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
      Nov 15 18:27:17 M103_2-sn465 OWFS[866]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
      Nov 15 18:30:17 M103_2-sn465 OWFS[866]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
      Hoping for a response,
      Thank you,
      Lubo
      • L
        Lubo last edited by
        I´m replying to myself :)
        I have never worked with Linux, so I search little bit and found this video: https://www.youtube.com/watch?v=T20jXu7rDCA
        Based on it, I understood how to solve my problem.
        I have edited evok.conf by nano text editor, where it is necessary to deleted all " ; " around [Extension 1]
        root@M103_2-sn465:~# cd /etc
        root@M103_2-sn465:/etc# nano evok.conf
          GNU nano 2.7.4                                          File: evok.conf
        use_schema_verification = False                 ; Enabling this will deny any requests that do not match the JSON Schema; NO$
        log_level = ERROR                                       ; Minimum severity of messages to be logged; one of INFO, DEBUG, WAR$
        port = 8080                                                             ; !!! Internal API port - only change if you are cer$
        webhook_enabled = False                                 ; Enables webhook notification - see e.g. https://sendgrid.com/blog/$
        webhook_device_mask = ["input","wd"]    ; List of device types to notify on (written as a JSON list) - adding AI will genera$
        webhook_complex_events = False                  ; EVOK will send POST requests with the same data as WebSocket, rather than $
        wifi_control_enabled = False                    ; !!! REQUIRES THE UNIPIAP WIFI CONTROLLER TO BE INSTALLED !!! Will allow ev$
        soap_server_enabled = False                             ; Enables the simple SOAP server; use only if you need the functiona$
        soap_server_port = 8081                                 ; !!! IF SOAP SERVER IS ENABLED, THIS PORT NEEDS TO BE UNIQUE (i.e. $
        [NEURON_1]
        ; Below you can find examples for connecting devices over UART; first example is a Neuron extension while the second is a cu$
        ; !!! Note that device_name has to match a filename in the /etc/hw_definitions directory !!! See /etc/hw_definitions/CUSTOM $
        [EXTENSION_1]
        neuron_uart_circuit = 1_01                              ; Optional, allows associating extensions with specific Neuron UART-$
        baud_rate = 19200                                               ; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORT$
        parity = N                                                              ; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SER$
        stop_bits = 1                                                   ; Optional, NEEDS UNIPI IMAGE TO WORK WITH UNIPI SERIAL PORT$
        ;[EXTENSION_2]
        ;neuron_uart_circuit = 1_01                             ; Optional, allows associating extensions with specific Neuron UART-$
        [OWBUS_1]
        owbus = /dev/i2c-1 --i2c=/dev/i2c-1:ALL ; Mandatory, scanned bus (--i2c=/dev/i2c-1:ALL or localhost:2122 or 'u' for USB dong$
                                                              [ Read 99 lines ]
        ^G Get Help    ^O Write Out   ^W Where Is    ^K Cut Text    ^J Justify     ^C Cur Pos     ^Y Prev Page   M-\ First Line
        ^X Exit        ^R Read File   ^\ Replace     ^U Uncut Text  ^T To Spell    ^_ Go To Line  ^V Next Page   M-/ Last Line
        Than:
        Ctrl o,
        Enter,
        Ctrl x
        reboot
        After reboot , Evok and Modbus started correctly.
