Wrong device model in EVOK (Patron)
EVOK provides incorrect information on Patron:
{ "glob_dev_id": 1, "last_comm": 0.06514811515808105, "ver2": "0.1", "sn": 60, "circuit": "1", "model": "M527", "dev": "neuron", <-- Should be patron "board_count": 2 }
Could you fix this, please?
Br,
Vesa -
Hello @Vesa-Kauppinen,
The 'dev' field describes an object type (similarly to di or relay) so the key has to be constant regardless of the PLC series. You are right, this can be a little bit confusing - it's a piece of history ;-).
Now, we will add the new field of a family containing Patron/Neuron/Axon string.
The 'dev' field fix is a breaking change of the existing API and will be subject to change within an upcoming new Major version.
