Push Button and Latching switch
  • Hello,
    I suppose it is possible to emulate a 230V push button with the relays but :
    Is it possible to plug in input to the UNIPI the output of a Latching switch (teleruptor) in order to know the state of the 230V circuit it control?
    Is it also possible to use as an input a push button at 230V?
  • Hello,
  • Hello,
    the DIs are max 24V DC only! Anything else will damage your UniPi. So you would need eg a external relay that will be switched by the 230V and will switch the 12/24V DC which will go to the digital input.
