UniPi and pi4j
Hi all,
I would like to build an extension to the pi4j library, and am doing some tests:
UniPi + Rasp 2 + raspbian
I cannot seem to get relay 1, GP07 to work. There is somethig I missing here, but whar is it?
I have confirmed that I have address 20 for the MCP23008:
pi@raspberrypi ~ $ i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- 18 -- -- -- -- -- -- -- 20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: 50 51 52 53 54 55 56 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- 6f 70: -- -- -- -- -- -- -- --
I can use:
i2cset -y 1 0x20 0x09 0x80 ```to control, with no issues. .. I get the following error when executing the program:
Number of relays to test: 8
Milliseconds to wait: 50
A serious error has occurred:
java.lang.ArrayIndexOutOfBoundsException: 128
at com.pi4j.io.gpio.GpioProviderBase.getPinCache(GpioProviderBase.java:69)
at com.pi4j.io.gpio.GpioProviderBase.export(GpioProviderBase.java:98)
at com.pi4j.gpio.extension.mcp.MCP23008GpioProvider.export(MCP23008GpioProvider.java:127)
at com.pi4j.io.gpio.GpioProviderBase.export(GpioProviderBase.java:79)
at com.pi4j.io.gpio.impl.GpioPinImpl.export(GpioPinImpl.java:158)
at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionPin(GpioControllerImpl.java:517)
at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionDigitalOutputPin(GpioControllerImpl.java:669)
at sfcountertester.SFCounterTester.<init>(SFCounterTester.java:93)
at sftestsuite.SFTester.main(SFTester.java:71)
Expect: 17 counts for relay: Relay2
Expect: 16 counts for relay: Relay3
Expect: 15 counts for relay: Relay4
Expect: 14 counts for relay: Relay5
Expect: 13 counts for relay: Relay6
Expect: 12 counts for relay: Relay7
Expect: 11 counts for relay: Relay8
Exception in thread "Thread-1"
java.lang.RuntimeException: java.io.IOException: Error writing to /dev/i2c-1 at address 0x20 to address 0x9. Got -10001.
at com.pi4j.gpio.extension.mcp.MCP23008GpioProvider.setState(MCP23008GpioProvider.java:203)
at com.pi4j.io.gpio.impl.GpioPinImpl.setState(GpioPinImpl.java:325)
at com.pi4j.io.gpio.impl.GpioControllerImpl.shutdown(GpioControllerImpl.java:939)
at com.pi4j.io.gpio.impl.GpioControllerImpl$ShutdownHook.run(GpioControllerImpl.java:888)
Caused by: java.io.IOException: Error writing to /dev/i2c-1 at address 0x20 to address 0x9. Got -10001.
at com.pi4j.io.i2c.impl.I2CDeviceImpl.write(I2CDeviceImpl.java:124)
at com.pi4j.gpio.extension.mcp.MCP23008GpioProvider.setState(MCP23008GpioProvider.java:201)
... 3 more
run-remote:
BUILD SUCCESSFUL (total time: 29 seconds)in addition I attach code:
package sfcountertester;
import com.pi4j.gpio.extension.mcp.MCP23008GpioProvider;
import com.pi4j.gpio.extension.mcp.MCP23008Pin;
import com.pi4j.io.gpio.GpioController;
import com.pi4j.io.gpio.GpioFactory;
import com.pi4j.io.gpio.GpioPinDigitalOutput;
import com.pi4j.io.gpio.PinState;
import com.pi4j.io.i2c.I2CBus;
import java.io.IOException;/**
@author gproost
public class SFCounterTester implements Runnable {private int numRelays;
private int minimumClicks = 10;
private int delay = 100;// create gpio controller
final GpioController gpio = GpioFactory.getInstance();// create custom MCP23008 GPIO provider
final MCP23008GpioProvider gpioProvider;// relays
static GpioPinDigitalOutput relay1;
static GpioPinDigitalOutput relay2;
static GpioPinDigitalOutput relay3;
static GpioPinDigitalOutput relay4;
static GpioPinDigitalOutput relay5;
static GpioPinDigitalOutput relay6;
static GpioPinDigitalOutput relay7;
static GpioPinDigitalOutput relay8;/**
@param numRelays
@param delay
@throws InterruptedException
@throws java.io.IOException
public SFCounterTester(int numRelays, int delay) throws InterruptedException, IOException {gpioProvider = new MCP23008GpioProvider(I2CBus.BUS_1, 0x20);
try {
this.numRelays = numRelays; this.delay = delay; if (numRelays >= 1) { relay1 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_00, "Relay8", PinState.LOW); relay1.setShutdownOptions(true, PinState.LOW); } if (numRelays >= 2) { relay2 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_01, "Relay7", PinState.LOW); relay2.setShutdownOptions(true, PinState.LOW); } if (numRelays >= 3) { relay3 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_02, "Relay6", PinState.LOW); relay3.setShutdownOptions(true, PinState.LOW); } if (numRelays >= 4) { relay4 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_03, "Relay5", PinState.LOW); relay4.setShutdownOptions(true, PinState.LOW); } if (numRelays >= 5) { relay5 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_04, "Relay4", PinState.LOW); relay5.setShutdownOptions(true, PinState.LOW); } if (numRelays >= 6) { relay6 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_05, "Relay3", PinState.LOW); relay6.setShutdownOptions(true, PinState.LOW); } if (numRelays >= 7) { relay7 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_06, "Relay2", PinState.LOW); relay7.setShutdownOptions(true, PinState.LOW); } if (numRelays == 8) { relay8 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_07, "Relay1", PinState.LOW); relay8.setShutdownOptions(true, PinState.LOW); }
} catch (Exception ex) {
System.out.println("A serious error has occured:");
ex.printStackTrace();
@Override
public void run() {switch (numRelays) { case 8: runTest(relay8, minimumClicks + 8, this.delay); case 7: runTest(relay7, minimumClicks + 7, this.delay); case 6: runTest(relay6, minimumClicks + 6, this.delay); case 5: runTest(relay5, minimumClicks + 5, this.delay); case 4: runTest(relay4, minimumClicks + 4, this.delay); case 3: runTest(relay3, minimumClicks + 3, this.delay); case 2: runTest(relay2, minimumClicks + 2, this.delay); case 1: runTest(relay1, minimumClicks + 1, this.delay); } // get out gracefully gpioProvider.shutdown(); // gpio.shutdown();
@param pin
@param number
private void runTest(GpioPinDigitalOutput pin, int number, int delay) {try {
System.out.println("Expect: " + number + " counts for relay: " + pin.getName()); for (int i = 0; i <= number - 1; i++) { gpio.setState(PinState.HIGH, pin); Thread.sleep(delay); gpio.setState(PinState.LOW, pin); Thread.sleep(delay); }
} catch (Exception e) {
If anyone can help, I would appreciate it immensely. Regards, George.
Hi all,
I can use:
... 3 more
run-remote:
@author gproost
@param numRelays
@param delay
try {
@Override
@param pin
@param number
This looks like maybe a bug in the Pi4J Java code and not in the application.
As far as i known the Pi4J library caches the pinmodes at the moment they are being initialized just in case you re-initialize a pin it throws an exception.
The error is an error showing that a certain entry in an Java Array does not exist at position 128, and hence throws an index out of bounds exception. I would discuss this one with the Pi4J developer as it is the Pi4J lib throwing the exception.
Hi John,
Yes issue is pi4j .. pin caching..
Currently under snapshot-1.0.1 fails … under version 1.0 works.
I need snapshot however due to improved serial behaviour.I have contacted the developers.
Regards
George
Hi George,
Have you tried jssc for serial connections? It controls both serial pins (using /dev/) and serial over usb. You would be able to use the 1.0 then.
Cheers,
John
Thanks John,
I'll look into that.
George.
