Installing evok manually
  • if you are like me and found the install-evok.sh to not be acceptable to your environment here is the quick and dirty you need to know. it would be nice if this team opened the wiki documentation and let people make this product better documented rather then just posts.
    First get I2C working - this assumes your Pi is updated and running 1.3 kernel
    sudo nano /etc/modules
    ```add the following on separate lines in the file.
    i2c-bcm2708
    i2c-dev
    Open boot config.txt
    sudo nano /boot/config.txt
    dtparam=i2c1=on
    dtparam=i2c_arm=on
    sudo reboot
    sudo i2cdetect -y 1
    00: -- -- -- -- -- -- -- -- -- -- -- -- --
    20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    **that worked correct? if not go fix it…**
    install and get the unipi evok package
    first, if you dont have git
    sudo apt-get install git
    cd ~
    git clone https://github.com/UniPiTechnology/evok
    get some foundation applications
    sudo apt-get install -y python-ow python-pip
    sudo pip install tornado toro jsonrpclib
    make and install PiGPIO from source
    cd~
    git clone https://github.com/joan2937/pigpio PIGPIO
    cd PIGPIO
    make
    make install
    'install' the files into the OS
    cd ~/evok
    sudo cp -r tornadorpc_evok /usr/local/lib/python2.7/dist-packages/
    sudo cp -r evok/ /opt/
    sudo mkdir -p /var/www/evok && sudo cp -r www/* /var/www/
    sudo cp etc/evok.conf /etc/
    sudo cp uninstall-evok.sh /opt/evok/
    create services and set script executable
    sudo cp etc/init.d/evok /etc/init.d/
    sudo cp etc/init.d/pigpiod /etc/init.d/
    sudo chmod +x /etc/init.d/evok
    sudo chmod +x /etc/init.d/pigpiod
    sudo chmod +x /opt/evok/evok.py
    set the services to start
    sudo update-rc.d pigpiod defaults
    sudo update-rc.d evok defaults
    you should go edit the ecok.conf because it uses port 80 by default and you dont want that
    sudo nano /etc/evok.conf
    find the "port = 80" and change it to something like "port = 8181"
    start the services now
    sudo service pigpiod start
    sudo service evok start
    then load up a browser and if you used my recommendation browse to http//PI.IP:8181
    now you can mess around with it a little and see that you did something
    next you likely want to read up on [https://github.com/UniPiTechnology/evok#api-examples](https://github.com/UniPiTechnology/evok#api-examples)
    i2c-bcm2708
    i2c-dev
    dtparam=i2c1=on
    dtparam=i2c_arm=on
    sudo reboot
    sudo i2cdetect -y 1
    cd ~
    cd~
    cd PIGPIO
    make
    make install
    cd ~/evok
  • Hello,
    i did the manual installation, step by step as detailed.
    The board is listed in the I2C, the services are started, but when i use a browser to approach the board i got the following message:
    ERR_CONNECTION_REFUSED
    Any idea why that may be?
    when i use the Python using JsonRPC program example, i get a similar error (see below):
    extract:
    s.relay_set(1,1)
    File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 639, in call
    return self.__send(self.__name, args)
    File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 523, in _request
    response = self._run_request(request)
    File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 556, in _run_request
    verbose=self.__verbose
    File "/usr/local/lib/python3.4/xmlrpc/client.py", line 1131, in request
    return self.single_request(host, handler, request_body, verbose)
    File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 361, in single_request
    self.send_request(connection, handler, request_body, verbose)
    File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 400, in send_request
    self.send_content(connection, request_body)
    File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 425, in send_content
    connection.endheaders()
    File "/usr/local/lib/python3.4/http/client.py", line 1086, in endheaders
    self._send_output(message_body)
    File "/usr/local/lib/python3.4/http/client.py", line 924, in _send_output
    self.send(msg)
    File "/usr/local/lib/python3.4/http/client.py", line 859, in send
    self.connect()
    File "/usr/local/lib/python3.4/http/client.py", line 836, in connect
    self.timeout, self.source_address)
    File "/usr/local/lib/python3.4/socket.py", line 509, in create_connection
    raise err
    File "/usr/local/lib/python3.4/socket.py", line 500, in create_connection
    sock.connect(sa)
    ConnectionRefusedError: [Errno 111] Connection refused
  • Hello,
    try shutting the evok service down by service evok stop or by kill command with the process id. Then run /opt/evok/evok.py and past the output here so we get more detailed info…
    Thanks!
  • Dear Tomas,
    i am working with python3.4 and therefore issues with evok.py because i think my 2.7 environment is not default env.
    I will start from a fresh debian install and first get evok running before i try installing python3.4.
    Should i have problems, then i come back online.
    Kind Regards,
    Rudy
  • Dear Tomas,
    took a fresh install from debian (2015/09/24) and it worked !
    #had to deviate from yr installation script as follows:
    #had to install the i2c-tools:
    sudo apt-get install i2c-tools
    #had to add sudo:
    sudo makefile # for pigpiod
    Thanks!
    Rudy
  • Dear Rudy and Thomas,
    I has a similar problem with tornado, toro, and jsonrpclib getting loaded into Python 3.5. I got around this problem by changing the following line in install-evok.sh file:
    "pip install tornado toro jsonrpclib"
    to
    "/usr/bin/pip-2.7 install tornado toro jsonrpclib"
    It forced the install to Python 2.7 libraries
    I updated build-essentials and python-dev for 2.7 (and all other versions) first:
    "sudo apt-get install build-essential python-dev"
