(very simple) Example for UniPi direct via PIGPIO
Hi all,
I am experimenting with the UniPi and I have to say, it is indeed very easy with the evok-api.
Within minutes was the board installed, the evok-api build and the webinterface running!One small comment about the install script:
use with the "sudo apt-get" and the "sudo pip" the -E option of sudo. This way the script also
will work in a network with a proxy. (if the proxy env is set of course)But I need a little help with my next experiment:
I want to "skip" the evok-api and try to use python and the PIGPIO lib to read the input
and switch the relay direct. I keep using the PIGPIO Deamon which came wit the install.
And also I import the pigpio.py which came with the evok-api.My bigest problem is that I do not fuly understand the I2C Bus principals with the UniPi
And that the evok-api is compleetly open, is fantastic! But I could not extract the complete
code for a very simple proof of concept.So can somebody help me and post a minimal block of code for reading a Digital Input
and switch one of the relays ?import pigpio import time def main(): i2cbus = 1 address = 0x20 pi = pigpio.pi() handle = pi.i2c_open(i2cbus, address, 0) > and here I get stock < pi.i2c_close(handle) pi.stop() if __name__ == '__main__': main()
Hi all,
A new day, a big cup of coffee and a smart collega (mh)…
...and we solved one part of the question:import pigpio import time def main(): i2cbus = 1 address = 0x20 pi = pigpio.pi() handle = pi.i2c_open(i2cbus, address, 0) print('status: ' + str(pi.i2c_read_byte_data(handle, 9))) pi.i2c_write_byte_data(handle, 9, 0) print('status: ' + str(pi.i2c_read_byte_data(handle, 9))) time.sleep(2) pi.i2c_write_byte_data(handle, 9, 15) print('status: ' + str(pi.i2c_read_byte_data(handle, 9))) time.sleep(2) pi.i2c_write_byte_data(handle, 9, 255) print('status: ' + str(pi.i2c_read_byte_data(handle, 9))) time.sleep(2) pi.i2c_write_byte_data(handle, 9, 0) print('status: ' + str(pi.i2c_read_byte_data(handle, 9))) pi.i2c_close(handle) pi.stop() if __name__ == '__main__': main()
Any comments ?
Please reply!
nice job.
The digital input is not difficult once you have this done. Just do not forget to set the PULL-UP resistor on each GPIO - the list of the GPIOs can be found in the documentation.
See unipig.py file line 646
Keep me updated with your progress
