Verifying signaling on IO1
  • Hi,
    i'm checking the input signal on IO1 (GPIO 4).
    gpio readall
    shows me a RPI B plus, GPIO 4 is BCM 23
    Then i'm using this to check the value :
    import RPi.GPIO as GPIO
    import time
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(23, GPIO.IN, pull_up_down = GPIO.PUD_UP)
    while True:
    if(GPIO.input(23) == 1):
    print("Input signal detected")
    time.sleep(5)
    GPIO.cleanup()
    But i'm getting an "Input signal detected" even when nothing is connected on IO1
    What am i missing?
  • Hi,
    gpio readall
    import time
    while True:
    time.sleep(5)
    GPIO.cleanup()
    What am i missing?
  • Hello,
    you should use BCM pin 4 for Digital Input 1… I see it is not clear from the documentation.
    I will fix it asap.
    Hope it helps.
    BR,
  • Okay Thomas, got it now. It's also triggering on a low… So following code makes more sense :
    import time
    GPIO.setup(4, GPIO.IN, pull_up_down = GPIO.PUD_UP)
    while True:
    if(GPIO.input(4) == 1):
    print("No Input signal detected")
    #time.sleep(5)
    else:
    GPIO.cleanup()
    Also interesting to know is that the ports trigger at 4.88 Volt (maybe even lower, but can't test this currently).
