Setting Listen Port
How can i set the Port in the /etc/evok.conf to :8080. In my file there is no entry for that.
Thank's in advanced
Thank's in advanced
it is defined in /opt/evok/evok.py file line 48: define("port", default=80, help="run on the given port", type=int)
I will change add an option in the conf file during the next week
WORKed! Fine and Thank's
I tried using the config file to change the port Evok was listening on and it wouldn't work. I found in the evok.py file at line 461:
port = config.getintdef(Config, "MAIN", "port", 80) define ("port", default=port, help="Listening port settings", type=bool)
which appears where the config sets the port but it wouldn't work. However, when I changed it to:
port = config.getintdef(Config, "MAIN", "port", 80) define ("port", default=8181, help="Listening port settings", type=bool)
it worked fine. Any ideas?
Try```
sudo nano /etc/evok.conf
