Wrong Temperature Signal
My DS18S20 shows me temperatures jumping between 7 and 90 degrees. Can anyone help me?With kind regards Chris
that is weird. What is the time between the "jumps"?
I set the interval on two seconds and there i have readings 7 90 55, etc. Is it possible, that the sensor has a hardware damage?With kind regards Chris
It may be possible. When did you start to see the jumps? Right after you received the sensor or it worked well for some time?
It was from the beginning, when i installed the one wire bus.With kind regards Chris
Do you have the possibility to make a new RJ45 connector?
