Compatible with RPI 2?
  • Hi Guys,
    can you please confirm, the UniPi module is compatible with RPi 2?
    Cheers,
    Titotarantula
  • Hi Guys,
    Cheers,
    Titotarantula
  • Hello,
    the RPi 2 compatibility test is in progress. But since the RPi2 requires much more power a separate power supply via the microUSB connector on RPi might be necessary (depending on how much processing power does your application require).
    This might be the only HW issue I can think of right now.
    Our evok API is not compatible with RPi2 for now because it requires pigpio to run (which does not support RPi2 for now).
    Regards,
  • +1 looking for RPI2 compatibility.
  • RPi2 compatibility confirmed and also updated the project on github.
    But since RPi2 may take a lot of power in heavy load and many USB devices connected it may be required to use external power source for RPi…
    Edit: wiki and documenation for UniPi 1.1. and RPi2 will follow later
