LED Dimmer
Hello UniPi Fans,
I would like to dim 12V LEDs in my living room, possibly by using the 1Wire 8xSSR/R module.
It takes 10ms for the SSRs to turn on/off. The ideal PWM frequency for dimming is above 200Hz.Am I on the right track?
DMX Dimmers might be an alternative but I do not know how to link those to a Neuron L203.
Thank you for your advice.
Rainer
Unfortunately 1wire is not a way to go. It is too slow and the IC does not support pwm.
If you are a little bit hw person, take a look at the 4ao/12pwm for i2c board.
Btw the Neuron supports RS485 (Modbus) and there are many boards for dimming based on rs485.
Br,
