    1 wire 4 digital input and 4 Relay output for the expansion module
    UniPi 1Wire Extension Modules (official)
      Thokoane last edited by
      hi
      1 wire 4 digital input and 4 Relay output for the expansion module 5 ports on the input side of the board i understand that the first 4 ports are for the 4 digital input, what is the 5th port for.
        the pins 1-4 are the digital inputs and the last one labeled with the inverse T is pin where the - of the power supply used for the DI should be connected.
          Thokoane @tomas_hora last edited by
          @tomas_hora
          Thank you Thomas
