Analog Input less precise
Hi there,
Is there any way I can configure Evok to be less precise on Analog input?
I'm using it for simple on/off detection, so I would be ok if I could set analog INPUT result to be rounded to whole volts.
For example:
Instead of current reading 0.006V I need to result be 0V.Is this possible?
I was unable to find any documentation of evok, is it available somewhere?Thank you!
Jirkaehm
Hi there,
For example:
Jirkaehm
Well you could do that in your app, but if you want to do it in evok, than https://github.com/UniPiTechnology/evok ... ok.py#L302 is the place to do.
Hi Tomas,
I was hoping for a configuration switch
But thank you for direction!
