Flow meter
I used a flow meter (https://www.adafruit.com/products/833) with RPi (the red wire to +5V, the black wire to common ground and the yellow sensor wire to pin #2.) It worked well.
How could I use it with UNIPi?
Almost the same way. See this example: http://unipi.technology/wiki/Reading_si ... of_devices
You can choose whether your flow meter will use 5 or 12V for the signal
How did you get this flow meter to work with unipi
