Distance measurements into Mervis
Hello team,
At SUNTHERM we're using the Unipi together with Mervis to control our heating system. As part of this system we need to monitor the waterlevel in a tank.
For this purpose we intend to use a HC-SR04 based ultrasonic device like this:
http://www.modmypi.com/blog/hc-sr04-ultrasonic-range-sensor-on-the-raspberry-piHow do I connect the 4 pins to the Unipi, when the GPIO header is used by the board to board connector?
How do I import the value from python into Mervis as a global variable?Looking forward to some valuable input:-)
Hello team,
I am afraid that this piece of HW cannot be used with Mervis because you need the exact time of the pulse from the sensor. Mervis is not a perfect solution for that because the DI are not read that often.
Br,
Hej Tomas,
Thank you for the response.
Would it be more suitable with a device like this:
https://www.adafruit.com/datasheets/1786_Chemical_eTape_Datasheet.pdfConnected to Analog input?
rgs Morten:)
You can use the first simple voltage divider schematics for reading resistance with UniPi 1.1. Below is a schematics with values calculated for use with sensor with 400-5000ohm resistance.
Also please remember that the onboard 12V might not be stable enough for using for such purposes!
