1W-4R-4DI
I bought a 1wire extension EMO R8 and i would like to know how to wire the 4 input! is there a documentation for this?EDITED: Due to fail in manufacture, some 1W-4R-4DI are labeled as EMO-R8!
See the example configuration file or: https://github.com/UniPiTechnology/evok ... .conf#L270
Thank you thomas, the config is ok but my question was about the wiring of the input. the Leds don't falsh when i close the contact..
Do you have the GND of your the power supply that you use for the contact connected to the GND pin of the DI on the 1wire extension? There are five pins on the digital inputs connector - 4di + 1gnd
Yes there are 5 pins, I've tried to wire between gnd and di1 and nothing happened. Don't you have an example of wiring? There is also a jumper JP1, what is it for?
I split the forum into a new topic because it is not about EMO-R8 but 1W-4R-4DI I guess. Here is a quick skech of wiring: http://imgur.com/cAfZkD2
